  4. Endian Firewall 2.3
QOS
  • Eagle
  • 18. Februar 2010 um 20:43
  • Eagle
    Hi!
    Ich bekomme das QOS einfach nicht zum laufen....
    Wie konfiguriere ich das QOS richtig?
    Hier mein Beitrag aus dem englichen Forum und dem Bug-Tracker:
    I've configured main uplink for QOS 2000kbit/s Up/Down and enabled it.
    the Firewall creates 4 Classes
    i created a new class called 'technic' (without ')
    QOS Device: UPLINK:main
    reserved: 10%
    limit: 10%
    Priority: 1
    net i created a rule:
    Source: <ANY>
    Class: technic
    Destination Network/IP: (none) I leaved it blank
    Service: <ANY>
    Protocol: <ANY>
    TOS: <ANY>
    I've applied the rule.
    Tested...... 2000kbit/s UP/Down :(
    This Rule does not work!
    I've tried to restart qos manualy:
    root@FIREWALL:~ # restartqos
    2010-02-11 15:03:00,235 - restartqos.py[13487] - ERROR - Migration has to be fixed!!!
    2010-02-11 15:03:00,236 - restartqos.py[13487] - INFO - Loading configuration
    2010-02-11 15:03:00,264 - restartqos.py[13487] - ERROR - RETURNCODE [iptables -t mangle -N QOS 2> /dev/null] 1
    2010-02-11 15:03:00,335 - restartqos.py[13487] - INFO - Setting QOS of device: eth1 [UPLOAD=2000, DOWNLOAD=2000]
    2010-02-11 15:03:00,384 - restartqos.py[13487] - ERROR - RETURNCODE [iptables -t mangle -N QOS_ETH1 2> /dev/null] 1
    2010-02-11 15:03:00,427 - restartqos.py[13487] - ERROR - RETURNCODE [iptables -t mangle -D QOS -o eth1 -j QOS_ETH1 2> /dev/null] 1
    Skipping invalid rule: {'inputdev': '', 'protocol': '', 'src': '', 'tos': '', 'dst': '', 'dscp_class': '', 'dscp': '', 'classname': 'class0003', 'mac': '', 'dport': '', 'sport': ''}
    ok, a the rule was skipped
    I've deleted the rule.
    I've created a new rule
    Source: IP
    IP: 192.168.123.30 (IP of my PC in GREEN Subnet)
    Class: technic
    Service: <ANY>
    Protocol: <ANY>
    TOS: <ANY>
    Tested......near 2000kbit/s UP/Down :(
    This Rule also does not work!
    What's gonig wrong?
    tryed an other endian 2.3, same result
    DANKE!
  • aender
    • 22. Februar 2010 um 21:34
    QoS ist derzeit schlicht und einfach unbrauchbar und funktioniert nicht.
    Ich habe einige Bugs reported. Leider bis dato nicht wirklich eine brauchbare Rückmeldung.
  • aender
    • 11. März 2010 um 14:19
    Konnte ein Vorabversion des gefixten QoS testen.
    Soweit funktioniert das Ganze schon nahezu perfekt.
    Es gibt noch ein paar Kleinigkeiten in der GUI zu korrigieren und dann wird mit der 2.3.1 das QoS auch so funktionieren wie es sollte.
    • 11. März 2010 um 14:35
    Ich frag mich nur wann die 2.3.1 erscheint :)
    lt. bugs.endian.com Roadmap ist das gerade bei 88%
  • aender
    • 11. März 2010 um 16:18
    Nur Geduld.
    Ich habe etwas Kontakt zu den Jungs bei Endian.
    Das Hauptproblem ist es die Migration von 2.2 auf 2.3.x stabil zu bekommen und einige Unschönheiten mit HA. Sprich Update und Hochverfügbarkeit. Sobald das reibungslos funktioniert gibt es ein Release. Meiner Meinung nach wird das in den nächsten 2 bis 3 Wochen passieren.
    Im Q2 wird es dann "codename: angry armadillo" geben. Neuer Kernel (2.6.23 oder höher) wird dann Unterstützung für XEN bringen und ein neues IPSec Kernelmodul möglich machen damit einige Bugs mit OpenSwan gefixt sind. Weiters wird mit dem neuen Kernel nicht nur ein verbessertes SPI möglich werden, sondern auch viele neue Möglichkeiten geschaffen werden wie dass "killen" von bestehenden TCP-Sessions.
    Zudem wird gerade hart an der API im Hintergrund gearbeitet. Derzeit basiert so ziemlich viel noch auf Phyton. Das wird sich in Zukunft ändern. Stattdessen kommt EMI (Endian Management Interface) zum Einsatz das auf Turbogears basiert. Somit werden eigentlich die kompletten Scripts für die GUI so gut wie neu geschrieben. Das braucht Zeit.
    Hinter den Kulissen passiert also mehr wie man wirklich sieht.
    Zudem gibt es ja auch noch eine Enterprise Roadmap:
    Enterprise - enterprise-2.3.1
    93%
  • _andreas_
    • 30. November 2011 um 10:08
    kurze Frage. Laut diesem Forenbeitrag sollte es ja ab der 2.3.1 funktionieren.
    Ich habe bei mir eine 2.4.1 und bekomme QoS nicht zum Laufen, bzw. zeigen die Einstellungen keine Wirkung
    Bei der Suche im Internet stolpert man nur immer über Meldungen, dass es nicht funktioniert und auch noch länger so bleiben wird.
    In der Roadmap und im Bugtracker sind noch jede Menge Tickets zu QoS offen.
    Kann mir jemand von Euch definitv sagen, ob es in der 2.4.1 Community funktioniert oder nicht?
    Ich bräucht lediglich eine Priorisierung für VoIP.
    Vielen herzlichen Dank im Voraus
    Andreas
    • 30. November 2011 um 14:53
    Soweit ich weiß geht das immer noch nicht . .. .
    https://www.efw-forum.de/www/forum/view…f=74&amp;t=1065
  • aender
    • 1. Dezember 2011 um 08:06
    Genau.
    QoS funktioniert immer noch nicht und ich sehe da auch keine Chance, dass sich in der 2.5 da was ändern wird.... Schade
  • _andreas_
    • 1. Dezember 2011 um 08:25
    Danke für Eure Antworten.
    Wäre es denn möglich die von mir benötigte VoIP-Priorisierung über die Console manuell einzurichten oder gibt es hier ein generelles Problem im Kernel?
    Ich hätte keine Problem damit, das händisch einzurichten - auch nicht, wenn ich es nach jedem Neustart nochmal machen würde.
    Viele Grüße
    Andreas
  • aender
    • 1. Dezember 2011 um 10:01
    An der Konsole kannst das machen.
    • 1. Dezember 2011 um 10:04
    Das würde ich dann versuchen per scripting so zu regeln das beim neustart
    die Config wieder mit geladen wird.
  • _andreas_
    • 1. Dezember 2011 um 10:44
    Okay, das klingt doch schon ganz gut. Nur weiß ich leider nicht wie? Ich schätze mal es ist kein Einzeiler :)
    Wenn ich das richtig verstehe, muss ich Traffic auf Port 5060 gegenüber allem anderen bevorzugen.
    Hat einer von Euch QoS für SIP auf einer Community Edition bereits im Betrieb und wäre so nett das Script zur Verfügung zu stellen.
    Herzlichen Dank im voraus
    Andreas
  • aender
    • 1. Dezember 2011 um 11:17
    QoS ist nicht ganz so ohne.
    Hier eine Diplomarbeit dazu. Da kannst du alles nötige nachlesen:
    http://www.qucosa.de/fileadmin/data…data/diplom.pdf http://www.qucosa.de/fileadmin/data…data/diplom.pdf
