  3. Eagle
Beiträge von Eagle
  • QOS
    • Eagle
    • 18. Februar 2010 um 20:43
    Hi!
    Ich bekomme das QOS einfach nicht zum laufen....
    Wie konfiguriere ich das QOS richtig?
    Hier mein Beitrag aus dem englichen Forum und dem Bug-Tracker:
    I've configured main uplink for QOS 2000kbit/s Up/Down and enabled it.
    the Firewall creates 4 Classes
    i created a new class called 'technic' (without ')
    QOS Device: UPLINK:main
    reserved: 10%
    limit: 10%
    Priority: 1
    net i created a rule:
    Source: <ANY>
    Class: technic
    Destination Network/IP: (none) I leaved it blank
    Service: <ANY>
    Protocol: <ANY>
    TOS: <ANY>
    I've applied the rule.
    Tested...... 2000kbit/s UP/Down :(
    This Rule does not work!
    I've tried to restart qos manualy:
    root@FIREWALL:~ # restartqos
    2010-02-11 15:03:00,235 - restartqos.py[13487] - ERROR - Migration has to be fixed!!!
    2010-02-11 15:03:00,236 - restartqos.py[13487] - INFO - Loading configuration
    2010-02-11 15:03:00,264 - restartqos.py[13487] - ERROR - RETURNCODE [iptables -t mangle -N QOS 2> /dev/null] 1
    2010-02-11 15:03:00,335 - restartqos.py[13487] - INFO - Setting QOS of device: eth1 [UPLOAD=2000, DOWNLOAD=2000]
    2010-02-11 15:03:00,384 - restartqos.py[13487] - ERROR - RETURNCODE [iptables -t mangle -N QOS_ETH1 2> /dev/null] 1
    2010-02-11 15:03:00,427 - restartqos.py[13487] - ERROR - RETURNCODE [iptables -t mangle -D QOS -o eth1 -j QOS_ETH1 2> /dev/null] 1
    Skipping invalid rule: {'inputdev': '', 'protocol': '', 'src': '', 'tos': '', 'dst': '', 'dscp_class': '', 'dscp': '', 'classname': 'class0003', 'mac': '', 'dport': '', 'sport': ''}
    ok, a the rule was skipped
    I've deleted the rule.
    I've created a new rule
    Source: IP
    IP: 192.168.123.30 (IP of my PC in GREEN Subnet)
    Class: technic
    Service: <ANY>
    Protocol: <ANY>
    TOS: <ANY>
    Tested......near 2000kbit/s UP/Down :(
    This Rule also does not work!
    What's gonig wrong?
    tryed an other endian 2.3, same result
    DANKE!
  • Port Forwarding V2.3
    • Eagle
    • 8. Februar 2010 um 15:27
    kann mir hier keiner helfen?
    die Standard Lösungen funktionieren bei mir nicht, da ich 12 IP Adressen am RED Interface habe....
    • Eagle
    • 3. Februar 2010 um 10:25
    unter der Community Version 2.2 keine Diskussion, haut alles hin
    jetzt kommts:
    Community Version 2.3 naja schaut alles ganz net aus.....
    Zugriff von aussen funktioniert auch ganz wunderpaar (zuerst mal etwas länger im Forum gestöbert aber habs hinbekommen)
    NUR:
    der Zugriff von innen, über die offizielle IP haut einfach net hin.
    Kann mir bitte wer dabei helfen? Oder sollte ich noch auf V2.2 bleiben?
    Welche Infos benötigt Ihr noch?
    Greez
    Chris
  • Port Forwarding
    • Eagle
    • 2. Februar 2010 um 15:03
    Bei der Version 2.2 auf die ich jetzt wieder zurückgegriffen habe, funktioniert ja alles, auch der Zugriff von innen über die offizielle IP zum internen Server.
    Das Problem liegt bei mir in der Konfigurtaion der Version 2.3, die ich nicht zum laufen bekomme.
    Allerdings hab ich keinen Router als DMZ sondern hab aller 12 IP Adressen direkt am UPLink (also Zone Rot)
    Greez
    Chris
  • Port Forwarding
    • Eagle
    • 2. Februar 2010 um 13:55
    jetzt kommts:
    NUR:
    Greez
    Chris
